Block connector R/R
mjvw
Block connector R/R
Post by mjvw »
Have subframe off, so checking wiring have notice the 3 yellow wires R/R connector block under seat in plastic cover are a little scorched ok at R/R end, would like to cut back the scorched wire and fit a new connector block. After reading most of the R/R posts the 3 yellow wires can be connected anyway?
But what block connector would this one work?
https://kojaycat.co.uk/epages/950000457 ... 3W-CNA-WHT
Everything is working as expected charging ok, it/s 2002 f2 finned type R/R.
So many questions just wish I had the answers, but this forum always has.
Storming About :thumbup:
Re: Block connector R/R
Yeah scrap it & fit a MOSSFET R/R...
mjvw
Post by mjvw »
sirch345 wrote: Wed Oct 27, 2021 7:48 pm A few links you may or may not have already seen:
http://www.vtr1000.org/phpBB3/viewtopic ... 84#p351482
https://www.superhawkforum.com/forums/k ... how-25117/
Now thats a good read sirch345 :thumbup: so i will change to a more rebust R/R in the mean time as in my OP can the 3 yellow wires be but anyway round in a new block connector and is the connector ok i linked in the OP?
mjvw wrote: Fri Oct 29, 2021 8:38 am
Yes 3 yella any order.. Red & green need to be fitted to the correct terminals so make a note of which way they fit...
mjvw
Post by mjvw »
Cheers much appreciated :thumbup: :thumbup: just going to purchase new connector bock new for now new R/R later.
As Mac says, anyway around for those three yellow wires from the alternator is fine.
As for the new connector block, it states it's meant for alternator use so I'm guessing it should be fine, plus it shows on Kojaycat's site one for a Fireblade using the same size terminals. You'll just need a crimping tool :)
mjvw
Post by mjvw »
Thanks have ordered from another supplier plus some petrol pipe clips. Seemed to be a better price FYI
mjvw wrote: Sat Oct 30, 2021 11:51 am Thanks have ordered from another supplier plus some petrol pipe clips. Seemed to be a better price FYI
I'll have a look at that, cheers for the link :thumbup:
