Drain the fork
___Norwegian___
Drain the fork
Post by ___Norwegian___ »
Im gonna change the oil in the fork. Im wondering if its enough to loosen this ones to drain em:
Im on my 25'th motorcycle :)
popkat
Re: Drain the fork
Post by popkat »
Are you serious :lol:
No remove the fork legs and do it properly, you need to get the correct amount back in and for that you need the forks off and standing upright any way.
It's not a difficult job and you've already got the wheel off.
___Norwegian___
Re: Drain the fork
..and the amount of oil from top is without the springs in place?
Re: Drain the fork
___Norwegian___ wrote: Thu Dec 02, 2021 4:13 pm ..and the amount of oil from top is without the springs in place?
Yes, no spring and the leg collapsed.
popkat
Re: Drain the fork
Post by popkat »
130mm if the forks are standard. 140mm if you have uprated springs.. use 10weight oil. Don’t forget to pump the inner cartridge to empty and then again to refill it.
___Norwegian___
Re: Drain the fork
That was easy peacy :thumbup:
Filled up with 450ml with Motul Expert 10W, got air out of the damper, and sat it at 130mm from top, fully compressed and without spring. A rather easy bike wrenching at. (Done the valves and also installed M-CCT'ers) etc.
