pipes under tank
northmanuk
pipes under tank
Post by northmanuk »
i had pics of were pipes are on my phone but i lost the phone can any one explain were what goes ple4ase
cheers
law
Re: pipes under tank
Take a look here:
viewtopic.php?p=492761#p492761
mjvw
Post by mjvw »
As request picture removed,your spot on after another look just now :thumbup:
Storming About :thumbup:
mjvw wrote: Sun Feb 06, 2022 9:15 am Fuel pipe cut off on this pic. The wider pipe is the petrol tank overflow runs down lefthand side of bike venting at front left of bike the smaller goes to a T piece going to fuel tap and rear carb that creates the vacuum for fuel tap to work.
2002 model no physical on/off tap.
:roll:
Rubbish... In that pic which is a 19ltr tank as stated. that smaller pipe is still the breather pipe & not the vac pipe. With the later bike the petcock is mounted on the frame & not the tank. The vac pipe still runs from the crank case to the petcock...
The big diffrence is when removing tank you only have to take one pipe off the pet rock...it will pish all the fule out of the tank unless you clamp it...
mjvw
Post by mjvw »
Thanks, MacV2 you have explained it better then I can my smaller pipe does go to the vac take of just under the rear carb and is T pieced to fuel unit, and it is a 2002 that has the larger 19l tank.
Just wanted to help as the OP as a 2004 spec storm.
mjvw wrote: Sun Feb 06, 2022 10:03 am Thanks, MacV2 you have explained it better then I can my smaller pipe does go to the vac take of just under the rear carb and is T pieced to fuel unit, and it is a 2002 that has the larger 19l tank.
mjvw, the OP is is confused enough as it is, the standard bike does not have a T-peice... Neither Sirch or myself were aware that it was a later bike so the pics posted of the pipework will be of no use...
mjvw
Post by mjvw »
As requested :)
northmanuk
:wtf: :( im aqt a loss i got two pipes from the carbs to the petrol tap which is mountedm on mframe two pipes mto the underside of each carb water pipes i think
on rh side of frame two pipes to some breather i think
two pipes from cam covers to air box
but after that im lost
northmanuk wrote: Sun Feb 06, 2022 8:00 pm :wtf: :( im aqt a loss i got two pipes from the carbs to the petrol tap which is mountedm on mframe two pipes mto the underside of each carb water pipes i think
I'm confused now too :crazy:
What year is your bike :?:
northmanuk
hi chris thanks for earlier info my bike is a f3 2003
To add to your pipe count it sounds like you still have the PAIRS gubbins fitted. Thats the anti smog shite fited to the later bikes. Some photos would be a good idea.
This can be taken off but you need to blank pipes off where ness.
Search for PAIRS deleat... search.php?st=0&sk=t&sd=d&sr=posts&keyw ... move+PAIRS
northmanuk wrote: Sun Feb 06, 2022 10:07 pm hi chris thanks for earlier info my bike is a f3 2003
Some good clear photo's here from the Superhawk site of how the fuel lines etc go as well as other hoses under the petrol tank:
https://www.superhawkforum.com/forums/t ... orm-26597/
northmanuk
i was thinkling if i sent photos am i correct i need to find a host site any ideas welcome thanks for all help so far
law
Have you got Tapatalk at all? That lets you place photos in your messages.
northmanuk
kev im still at the wind up record player stage :D
