Speedo bolt
SlingVTR
Speedo bolt
Post by SlingVTR »
Has anyone got the silver hex bolt thing ive highlighted in the attached picture
Re: Speedo bolt
Probably, be out in the cave later & have a look.
How have you managed to lose that ? :lol:
Re: Speedo bolt
According to this it's not a separate bolt ???
I have a couple of spare clock sets I'll have a look for you...
https://www.ronayers.com/oemparts/a/hon ... peedometer
SlingVTR
Re: Speedo bolt
Post by SlingVTR »
Bought the bike like it, i dont know what its function is there is just an unthreaded hole there atm.
Re: Speedo bolt
Ok so I had a look at an old set I have, the bolt does turn with an allen key but will not unscrew. Therefore I think its a press fit but with a little persuasion it didn't want to pop out...
So I have a complete outer case if you want it ?
Either get the offending bolt out or just replace the case. 5 screws hold it on, the screws are with it so you can see which ones need undoing.
Replacing means fairing off, un-plug the clocks, 2 block connectors, 3 bolts hold it to the frame & its off. Flip it over on a bench, 5 screws, replace & put it all back on.
