Ticking Over..
SlingVTR
Ticking Over..
Post by SlingVTR »
Recently had carbs rebuilt was ticking over 1200rpm constantly before, the rebuild was a clean and all the rubbers replaced...was fine after after a 20m ride. Next time i took it out for a heat cycle it was up and down between 1500/1100....any ideas?
Re: Ticking Over..
Air leak. Check the carb rubbers and make sure the carbs are properly seated.
You can check by spraying a little squirt of brake cleaner near the carb rubbers and see if the revs rise.
SlingVTR
Re: Ticking Over..
Post by SlingVTR »
Well just had a 70 mile ride and the tick over was fine again 1200rpm pretty stable, i guess the bike identifies as a female then.
