Wooden rear brake
Bikemad61
Wooden rear brake
Post by Bikemad61 »
Foe those of you that use it, any hints on how to improve it, It doesnt help the handling when I have to stand on it to get any effect! Changed the pads, serviced the calipers ,etc, etc, etc
Lead! Follow or get out of the way. And RED is the fastest colour
New hose, Service the master cylinder?
Not much left. The most common is a build up of crud around the piston seals which stops them from moving back properly but that doesn't give you shite braking, just poor braking and binding brakes :(
What's the condition of your disc like? If it's got ridges it will take a little time for the pads to bed in
stevieVTR
Post by stevieVTR »
For a quick fix I fitted EBC HH pads, locked up the rear first time out because I wasn't expecting any improvement. Now just waiting to fit the ss rear hose to add a bit more stopping power...
.... no more bike, divorce sucks!!!!!!!!!!!!!
Has your bike down loads of miles :?: If it has the pin on the end of the front bolt (caliper fixing bolts) which allows part of the caliper to float may be badly worn, if it is the pad(s) may not be touching the disc square on :!: To check this apply the rear brake by hand and see if all of the pad surface is actually touching the disc :!:
Bikemad61
Post by Bikemad61 »
Cheers guys, already have the EBC HH pads, going to change the hoses and try all your suggestions, have all week off and she is at work, great! :D
