after markek exhausts
macfreebe
Post by macfreebe »
Was thinking of putting on after market exhausts as have got standard ones that seem to suffocate bike .Was on ebay but there seems to be a lot of options has any 1 got any advice on this
benny hedges
Re: after markek exhausts
Post by benny hedges »
stick what you want on it m8 theres a million choices, high level, low level, carbon, stainless, ally, whatever you want.
you most probably wont have to rejet unless you fit a k&n as well.
alternative is debaffle the originals..... search 'bafflectomy'
Cheap & easy fix is to remove the baffles from the standard pipes. Search for ''Baffelectomy'' Sounds much better, someone will come along & tell you that theirs passes an MOT with such altered pipes. Lots of others will come along & tell you which brand of pipes they have on, how good they sound ect ect.... With some after-market pipes you will need to re-jet carbs, new air filter & probably Dyno set up to get the best out of them. They will all however be much lighter then the standard pipes.
Mac....Running standards al-a-baffelectomy. Happy but slightly deafer.....pardon?....it's half past three......
I'll see your baffelecomy & raise you a CCT & throw in a rectifier!
alec
Post by alec »
MacV2 wrote:Cheap & easy fix is to remove the baffles from the standard pipes. Search for ''Baffelectomy'' Sounds much better, someone will come along & tell you that theirs passes an MOT with such altered pipes. Lots of others will come along & tell you which brand of pipes they have on, how good they sound ect ect.... With some after-market pipes you will need to re-jet carbs, new air filter & probably Dyno set up to get the best out of them. They will all however be much lighter then the standard pipes.
i've got microns on mine mate with standard carbs and they sound the nuts, you've heard it.
Eclectic
Post by Eclectic »
Ive just drilled my baffles a bit. But if I was to go the full hog how loud would it be? I very much intend to hit Snetterton a few times this year, and they have a 105dB sound limit, which I dont want to go over.
I have the full back pipe removed from my stock ones, and I think it is less noisy that Microns I had before...................but it is a good V2 noise now.
I dont know teh noise level, but I didnt trigger the Donington noise meter, so you should be OK.
And the bonus is that it all fully stamped up so the MOT guy just passes me every year
Eclectic
Post by Eclectic »
Just drilled mine out, couldnt be bother to await a reply, man alive... rumble in the jungle. Missus is properly rolling her eyes haha
benny hedges
Eclectic wrote:Just drilled mine out, couldnt be bother to await a reply, man alive... rumble in the jungle. Missus is properly rolling her eyes haha
ahaha good man!!! :bobby2: :bobby2: :bobby2: :bobby2: :bobby2: :bobby2: :bobby2:
Eclectic
Post by Eclectic »
V2 PR0N by Nigel Thurgood, on Flickr
I call it...V2 Pr0n.
BTW, Ill get nicked for this? lol! Now you tell me :Ball Kick:
pinkyfloyd
Post by pinkyfloyd »
If I was to go ahead and take the hammer drill to mine would I:
A: Need to rejet the carbs.
and
B: Buy more standard ones to keep the MOT people happy?
Eclectic
Post by Eclectic »
I'm expecting to fail the mot tbh. As for rejetting, I haven't rode long enough to tell if power is down as I only went out to get fuel. But she still power wheelie well.
Sent from my Desire HD using Tapatalk
My MOT is fine with debaffled pipes. they knows something is missing, but he cant work out what I have done!
I have spare standard ones, but havnt botherd for the last 3 yrs, and no bother with 2 seperate testers.
I think you might be OK on stock jetting, but cant say, as I changed to Race cans & K&N Filter so I had a DynoJet kit added...............then I got rid of the Micron Race Cans as they were just too loud, and went back to modified stock cans.
As I understood it the MoT can't fail you on loud ones, just issue an advisory.
But they can fail you if there's leaks or loose bits.
there's no dB meter used on a MOT, so that's all they can do.
What no-one's mentioned is the weight saving?
Standard ones, even with debaffling, are horribly heavy, compared to carbon (Mmmmm, lovely carbon) ones.....
pinkyfloyd
Does that mean Tony is going to splash out and buy us all Carbon mmmmmm lovely carbon ones? :lol:
