HELP ME PLEASE
Re: HELP ME PLEASE
tattoo wrote:you can do it with the engine in the frame..look in the knowladge section for the info you need and print it off if you don't have a manual.
Agreed!
You can undo the two lower rad supports, and the oil cooler bracket bolts and drop the oil cooler down to rest on a rag on the back of the mudguard.
This saves you having to drain the oil or disconnect the oil cooler lower connections.
Take off the exhaust system, and although it's possible to do the whole job with the fairing on, (just about), it's infinitely easier with it off.
Turn the engine to TDC front cylinder with the cam lobes facing in the correct position before you undo the cam cap bolts, and as long as you don't disturb it, the engine will still be in the correct place when you come to put the cams back in and reset the cam timing.
clinty
Re: HELP ME PLEASE
Post by clinty »
small update for you all.i have taken the offending cct out and manualy ajusted it to push the can chain down. i can now turn the engine all the way round with no horrible clicking noise. does this mean i am a lucky sod and have not bent anything or should i still strip it down.thanks
Re: HELP ME PLEASE
1) dont turn the engine over till you have reset the timing.
2) take off the cam cover reset the timing and check the valve clearances, if they are in spec [or too small], you could be lucky
tattoo
Re: HELP ME PLEASE
Post by tattoo »
if your lucky and the valves/clearances are ok i'd still fit manual cct's...that way your very unlikly to go through this again.
