Thanks Ben for that reply mate.Stormin Ben wrote: Two thoughts on this Chris
1. The pushrod that runs through the engine from the slave cylinder through to the clutch is directly in line with the chain. Chain lube gets flung off onto it
Try removing it and giving it a good clean in paraffin or similar
2. Mine was quite grabby on reasonably brisk launches. I fitted heavier springs and while it was apart I set to the clutch basket with a fine file.
Over time the plates can wear a notch / indent in the face. This then causes the plates to stick a little bit rather than engage freely.
Filing this completely cured the problem
I must admit the clutch push rod sticking is a good thought as that would give a delayed reaction, that's one idea that had slipped my mind. I normally keep on top of these things, but it's worth checking I agree, as it's probably been longer than I think since I last cleaned that area up, including the push rod. I'll try that first.
