leevtr wrote:One is under the tank ( Rear one that is ).To find the front plug,if you look at the front of the engine from under the headlight you should spot it, or at least the lead to it.MissEd wrote:Thanks for that info.
I have dot4 fluid...
So it is the same fluid for clutch and break .. ?
Take it the spark plugs are under the base of the air-filter container - can't see how to get that orft
I was probably near you today, had a ride out to baldock, via Bishops Stortford etc.
I looked everywhere under the tank with air filter removed (but not base of container).
Thanks for the info.. I shall try again..
Yeah - I am Much Hadham, so no distance for your passing
