help help i need an answer
northmanuk
Post by northmanuk »
i have tried twice to seal the generator side casing both times using a new gasket this is what ive done
clean both faces of joint making sure no bits of gasket are left
fit gasket over spigots
tighten bolts
fill engine with new 4 l of oil
start engine after a few mins oil comes out
repeat above cost 51.00
i have checked the crank casing and the gen case no visible damage :wtf:
cheers law
Re: help help i need an answer
are you missing the rubber grommet that seals the 3 yellow alternator wires into the casing? or is it not seating correctly?
northmanuk
no i got that its leaking around bottom of casing
start it to get a little heat in the casing then when it cools give it another little nip up.
When you levered it off, did you use a chisel or a blunt screwdriver?
May be there is a hairline crack in the alternator casing?
If you have a spare from the old engine it could be worth trying that,
northmanuk
re hammer chisel no lump hammer 8O
i have just ordered another casing
do you know what the metal rod is for bottom left as you look at the stator
northmanuk wrote: Tue Sep 06, 2022 4:40 pm re hammer chisel no lump hammer 8O
Do you mean the spindle for the starter gear :?:
As pointed out with a screwdriver in Mac's photo below:
That spindle can only be removed with a magnet.
northmanuk
it can be done another way but that would be telling
northmanuk wrote: Wed Sep 07, 2022 3:09 pm it can be done another way but that would be telling
I was trying to avoid the suggestion of taking off the casing then knocking the bike off it's sidestand...
