CCT
CCT
I read the technical articles of the forum and I see that many vtr have a problem with cct I have a varadero with 170000kh and before that I had another varadero with 110000kh. I never had a problem with cct. because the engines are almost the same could not be mounted by varadero;
Re: CCT
Auto CCT failure still happens with Varaderos
https://honda-varadero-uk.org/forum/ind ... pic=8632.0
Properly fitting manual tensioners will ensure it can never happen.
Re: CCT
yes Honda puts coloured dots on them that people interpret in many different ways as folk read the future using tea leaves. And yes Honda issued a new part no. on later auto CCTs but they still fail with alarming regularity. There are numerous horror story threads here on the consequences. Classic one was a new Storm owner having his fail after only 48 hours of ownership
Jun 2014 > "The dreaded cct let go bending all 4 valves and bending 2 valve guides aswel as killing the piston .These were changed for oem honda auto tensioners only 4 months ago prior to ownership 800 miles ago."
dreaded cct after 48hr ownership :-( > http://www.vtr1000.org/phpBB3/viewtopic ... 23&t=33856
Spot the pattern...
3rd Replacement CCT! > http://www.vtr1000.org/phpBB3/viewtopic.php?t=3628
CCT Death Rattle..........maybe!! > http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=9148
CT cost of repair?? > http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=4619
Engine rebuild or swap > http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=32316
Re: CCT
They can be adjusted at the same time as when the valve clearances need measuring - but I've not had to look at mine in over 35,000 miles.
Have a read through this - some things might not be applicable to your Varadero but there's still quite a bit in common between the two Hondas i.e CCTs, R/R, shock linkages etc.
Bike Maintenance and Upgrades/Modifications > viewtopic.php?p=304638#p304638
Re: CCT
probably because I run it every day in winter and summer maybe that's why I had so many kilometers and I had no problem. once I had put 20W 50 oil and as the ambient temperature dropped when I started the engine it made a creepy noise for two seconds from the timing chain my engineer told me. with which I changed the oils all well.
- rollingthunderx2
Re: CCT
No amount of paint spot changes will save you.
CCT failure victim in recovery.
Re: CCT
Your engineer was wrong.Christos wrote: ↑Sat Nov 21, 2020 3:33 pm probably because I run it every day in winter and summer maybe that's why I had so many kilometers and I had no problem. once I had put 20W 50 oil and as the ambient temperature dropped when I started the engine it made a creepy noise for two seconds from the timing chain my engineer told me. with which I changed the oils all well.
It was the starter reduction gears
