Installing manual headlight switch
GARID
Post by GARID »
Hi guys, im trying to install my new manual headlight switch on my motorbike but im novice at wiring so i need help. I ordered following switch
And i have 3 wires from headlight
which one is plus wire? and can i install 2 wires switch on 3 wires light?
acrmnsm
Re: Installing manual headlight switch
Post by acrmnsm »
At the risk of being dumb, what is wrong with the standard item?
1997 Red Storm, 3 others in bits...
"Devonshire born and Devonshire bred, strong in the arm and thick in the 'ead."
GARID
Post by GARID »
acrmnsm wrote: Wed Aug 28, 2024 3:49 pm At the risk of being dumb, what is wrong with the standard item?
making less power consumption
acrmnsm
Post by acrmnsm »
ahh wait, in the USA you have daylight running lights??
Sorry, most here are UK or European and we are allowed to turn ours off...
You might be better off finding a UK left hand switch gear. I bet you pint of Cider that a magic man by the name of @MacV2 has got one he will sell you.
acrmnsm wrote: Wed Aug 28, 2024 4:34 pm ahh wait, in the USA you have daylight running lights??
UK one wont fit the connector blocks are different.
Mac N Franks Acme parts department no longer sells outside the UK. The paperwork's too much for Frank to handle...
The later model UK bikes, post 2001, have the lights permanently on with the ignition. I tried to wire an early switch on to mine when I first got it, to give me the choice, but I lost high beam and the passing light, if I remember correctly.
xeris
Post by xeris »
~ Mark Twain
acrmnsm
Post by acrmnsm »
I couldn't live without my flasher, you feel like and F15 pilot firing off beams of light at all those in your way.
I changed mine back to standard when I realised it wasn’t a simple fix.
MK_WF
Post by MK_WF »
If you need to switch the front lights on/off with that switch, it'd theoretically work to
- cut the green wire at the bulb plug
- solder one end to red and the other to blue of your switch
That switches off the ground connection for the bulb, so neither regular nor high beam should work.
BUT: That switch is surely not rated for the required amperage and also the tiny cables will result in a high voltage loss (i.e. "darker" lights when switched on.)
Bye
Martin
GARID
Post by GARID »
MK_WF wrote: Sat Aug 31, 2024 5:09 pm If you need to switch the front lights on/off with that switch, it'd theoretically work to
Thank you, i soldered white wire for low beam and it works like charm :D
