upswept cans
haynesjones66
upswept cans
Post by haynesjones66 »
been trawling for ages trying to find a post about tilting std silencers higher. any ideas? thanks
Re: upswept cans
haynesjones66 wrote: Mon Oct 28, 2024 1:55 pm been trawling for ages trying to find a post about tilting std silencers higher. any ideas? thanks
I had some brackets made to give cans the upswept look.
They will not work on standard cans because you have to move the mounting straps.
The ones I have use the std footrest hangers
The standard cans can be rotated up but you would have to make a different bracket to do it.
http://vtr1000.org/phpBB3/viewtopic.php ... a07c147a28
haynesjones66
Re: upswept cans
good idea that, but there was someone on here using standard cans
Re: upswept cans
But why would you want to use standard cans? They're about four times the weight they need to be, and not, in my opinion, visually attractive.
If it's to avoid upsetting the neighbours, there are legal, quieter aftermarket options.
Also, if you're getting vibration through the footrests, changing the cans to aftermarket ones fixes it.
haynesjones66
Re: upswept cans
valid point. bit short of cash so using what i have. although if anyone has some used stumpies i'd be interested. my proposed tail end is so short, long standard pipes look a bit daft, so its either tilt them up or short cans
Re: upswept cans
If you are using after market link pipes i have a set of delkevic stubbies here, iv only used them about 300 miles so as new with straps, they are loud mind you :clap:
haynesjones66
Re: upswept cans
are they illegal loud? and are they high or low level? are they marked Not for road use?
pete
Re: upswept cans
haynesjones66 wrote: Wed Oct 30, 2024 8:01 am are they illegal loud? and are they high or low level? are they marked Not for road use?
pete
they have a few numbers stamped on them but it doesnt say not for road use, but they are proper loud :lol: . its just the cans and straps i have not the link pipes so will bolt on to after market links regardless if they are high mount of low level
haynesjones66
Re: upswept cans
pm sent
haynesjones66
Re: upswept cans
many thanks to fabiostar. i am now the proud owner of some delkevic stumpies. they are loud just to look at..
Re: upswept cans
haynesjones66 wrote: Sat Nov 09, 2024 9:17 pm many thanks to fabiostar. i am now the proud owner of some delkevic stumpies. they are loud just to look at..
:lol: :lol: :lol: that they are but they have a nice growl outa them on a v twin :thumbup: :thumbup:
